First post, by keropi
Hello!
anyone here has a Diamond Stealth 64 VLB (S3 Vision964) card and can upload the BIOS? 😊
(NSSI can create a VGA BIOS dump from DOS so there is no need for a programmer or even to remove the card/chip)
(image borrowed from http://www.vgamuseum.info)
Need it to potentially finish repairing such a card, thanks in advance!
Reply 1 of 8, by Predator99
Hi Keropi, my card:
The attachment IMG_4835.JPG is no longer available
Reply 2 of 8, by Predator99
...but have some difficulties with the EPROM, every time I read it it has a different checksum. And the area that differs is at a differnt location each time. Will try again later...
Reply 4 of 8, by Predator99
Think now its OK
IBM VGA Compatible BIOS. Stealth 64 Vers. 1.07 (c) Diamond Computer Systems, Inc. MB display memory installed 03/31/95
The attachment Diamond Stealth 64 VLB.rar is no longer available
Reply 5 of 8, by keropi
@Tronix
the U version of the BIOS is to be used when the S3 chip is made in Taiwan
@Predator99
thanks! it's exactly what I was looking for - I will burn and continue repairs!
Reply 6 of 8, by Tronix
keropi wrote:
@Tronix
Interesting! I compare "964_107u.rom" with "Diamond Stealth 64 VLB.BIN" and see only two differences:
0000003B: 2F 30
00000136: D1 D0
Offset at 0x3b and 0x136 looks like data tables, not code. Probaly, this is constants for memory clock or chip clock speed...
https://github.com/Tronix286/
Reply 7 of 8, by Predator99
Tronix wrote:
Interesting! I compare "964_107u.rom" with "Diamond Stealth 64 VLB.BIN" and see only two differences: […]
keropi wrote:
@Tronix
0000003B: 2F 30
00000136: D1 D0
Interesting..so it has the same text in it, identical version. In fact its only 1 byte difference, I assume the other differing one is for checksum calculation. Are you going to test both, keropi?
Reply 8 of 8, by keropi
nope I will only test with the BIOS you provided Predator99 - and as a sidenote the BIOS is the same as the PCI version that was found here: Looking for Diamond Stealth 64 PCI BIOS (S3 Vision964)
in this same thread on the 2nd page Avalon mentions the Diamond note he has about the H and U bios difference , I just go by that 😀
