First post, by Drogg
Great forums you guys are running here. I've lurked for a month or so, and I figured maybe you guys could help me with something.
I recently decided to try and get Ultima Underworld [thus far only the first one] running under XP Professional. I downloaded an abandonware copy, Cabirus' fix and the official patch. I've set compatibility mode for UW.exe to Win95, maxed out EMS memory, and set it to run in 640x480 / 256 colors / no visual themes. Every time I've loaded it up, with or without VDMSound, I've gotten the following error:
Cannot run Underworld.Out of EMS Memory. Error code C001
I did a search for old threads and found this . Dominus hinted that maybe EMS wouldn't be working altogether? If it wasn't, is there a way I could confirm that?
All my system specs are in my user info. Thanks for any help.
