First post, by Kaleidoskop
Hello people,
I have an old Voodoo 2 that's definitely dead. I came up with the idea that maybe I could harvest the VRAM chips from it and use it to upgrade my older VLB type video cards with more memory (they have empty slots for this). The case type is the same on both chips, and so is the pinout and voltage. But the newer Voodoo chips are way faster, and not quite the same. The VLB boards use "CMOS DRAM" (hy514260b) whereas the Voodoo uses "EDO DRAM" (sm81c256k16cj-25).
Would it be possible to do this?
Datasheets for both
VLB: http://static6.arrow.com/aropdfconversion/e1e … 06e/514260b.pdf
Voodoo: http://www.ic72.com/pdf_file/s/11555.pdf
Reply 2 of 4, by TheMobRules
I have a VLB card that mixes FPM and EDO, works just fine. It's a Diamond Stealth 64 DRAM T VLB (Trio64 chip).
So I guess EDO support depends on the graphics chip.
Reply 3 of 4, by Doornkaat
Two or three of my VLB cards worked fine with the same memory as three of my V1: Mosel Vitelic V53C16258HK30
