First post, by rick12373
Can anyone point me in the right direction for a compatible PCMCIA WIFI card for my ancient 1200 Series Presario laptop? It is running Windows 95. I was given this laptop and it is in perfect condition. I don't think it ever had much use. I have been plugging it in to a separate monitor and it has been great. I know it won't be able to do much on the internet in this day and age but I would like to play about with it none the less just for fun.
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
Reply 1 of 9, by Sedrosken
WiFi on Windows 95 is going to be a no-go in most cases. You may try to find an Orinoco Gold card, but I think those top out at 802.11b and they might not have 95 drivers, just ones for 98 or better. You'd be better off getting a PCMCIA ethernet card instead and physically wiring into your LAN as you would on a desktop. Depending on what kind of slot you've got, whether it be 16-bit PCMCIA only like on my T2130CS or 32-bit PCMCIA, or even CardBus capable, you may have to be more discerning in what you pick up. Trying to find something for non-CardBus slots was like pulling teeth on eBay, especially for a card with the dongle still with it. I ended up getting a NOS Intel PRO/100 PC Card, though mine had the big qualifier that it was 16-bit only.
In your case, without knowing an exact model (1200 series can be a little vague) I'd say that you're running 95 instead of 98 or 2000 would be the big problem to getting WiFi working on there.
Shoushi: Dimension 9200, QX6700, 8GB D2-800CL5, K2200, SB0730, 1TB SSD, XP/7
Kara: K7S5A Pro, NX1750, 512MB DDR-286CL2, Ti4200, AU8830, 64GB SD2IDE, 98SE (Kex)
Cragstone: Alaris Cougar, 486BL2-66, 16MB, GD5428, CT2800, 16GB SD2IDE, 95CNOIE
Reply 2 of 9, by wiretap
A Compaq Presario 1200 series should be running Windows 98. It looks like the minimum processor they came with was an AMD K6-2 or Pentium MMX. If you installed Windows 98, you could use almost any older PCMCIA wireless adapter. I usually use a Linksys WPC54G since it supports connecting via WPA2 and has a separate Linksys program that you connect to AP's with. It works well with my Toshiba Libretto 110.
My Github
Circuit Board Repair Manuals
Reply 4 of 9, by rick12373
It is running a Pentium MMX 150. It is this model. https://www.cnet.com/products/compaq-presario … -mb-ram-1-6-gb/ . It came with Win 95 installed when new and has all of the Compaq utilities etc installed. I don't want to go to 98 on this one. I want to keep it original, so I need to make sure the WIFI card is compatible with Win 95.
SB 16 Value CT2770
Reply 5 of 9, by wiretap
Oh, that's a Presario 1600 series. If you have Windows 95b, you can use a Netgear MA401 PCMCIA wireless-b adapter. (Type II) It has Windows 95b drivers and compatible application for connecting to AP's. It only supports WEP of course..
My Github
Reply 7 of 9, by Solplay
Uhh, that's a Presario 1610? I'm guessing that the Presario 1200 is not what you have?
Either way, you are restricted to only two well-known options as far as I know. One is the Cisco Aironet 350 AIR-PCM352, and the other is the Netgear MA401 (as someone has mentioned above). Both of them are limited to the 802.11b standard, and they do not support WPA2 or even WPA as far as I am concerned. At most, they would support WEP.
The MA401's driver page can be found and downloaded here, while the AIR-PCM352's driver page involves registering a Cisco account to download the driver.
Reply 8 of 9, by rick12373
Yeah it's a 1610. I got mistaken as I think I have a desktop Presario that is a 1200, although I could be mistaken as that is in my office at work right now. I got 4 old desktops and this laptop at the same time. Thanks for the suggestions. I will see if I can get one.
SB 16 Value CT2770
Reply 9 of 9, by Warlord
If you had 98se, there is Funk Odyssey and have wpa2. 95 is cool and all but its limited, you can just use 98lite if u want to use 95 explorer. 🤣
