First post, by precaud
Found another interesting item downstairs today. An IBM FRU 64F4148 floppy drive of the 2.88MB kind. Made for IBM by Mitsubishi.
Has what looks like a standard 34-pin interconnect, but no separate power terminals.
I have an Intel Plato motherboard that supports 2.88M drives, so I hooked it up. Nada.
Is this another case of proprietary interface? How does one test these? Do I need to get special media to do so?
Reply 1 of 6, by Caluser2000
Yes proprietary. Power is supplied through the ribbon cable. Yes 2.88meg floppies are special. Test using a system with the same interface, a PS/2 system most likely. Good luck.
Reply 2 of 6, by Jo22
Depends on the point of view. It was made by IBM, creator of the IBM PC line. 😉
So if the creator decides to make improvements/changes to the orginal design, is that "proprietary" or not ?
Anyway, I get the point. Even though the floppy interface as we know it, was non-standard, as well.
The original Shugart floppy interface was different from that the first IBM PCs used.
Reply 3 of 6, by precaud
OK thanks. Probably will not mess with it, then.
Reply 4 of 6, by Caluser2000
No problem mate. Some folk make a mountain out of a mole hill when the outcome is obvious. Give/sell it to a PS/2 guy is the best thing you can do with it. They're prone to there own problems, caps going and the like. This thread will tell you all you need know and then some. https://www.dslreports.com/forum/r6949611-2-8 … MB-Floppy-Drive
Reply 5 of 6, by precaud
Thanks again. I'll pass it on to someone who can make use of it.
Reply 6 of 6, by Sedrosken
2.88M floppies are one of those deals where if you can get something out of it, it's nice, go ahead; however if you can't, there's no shame in it. 1.44M drives will handle roughly 99.998% of the disks you'll find in the wild anyway.
Shoushi: Dimension 9200, QX6700, 8GB D2-800CL5, K2200, SB0730, 1TB SSD, XP/7
Kara: K7S5A Pro, NX1750, 512MB DDR-286CL2, Ti4200, AU8830, 64GB SD2IDE, 98SE (Kex)
Cragstone: Alaris Cougar, 486BL2-66, 16MB, GD5428, CT2800, 16GB SD2IDE, 95CNOIE
