root42 wrote:I got an YD380 floppy drive. It is correctly detected during boot but it will read only one out of twenty floppies. Formatting floppies doesn’t work at all.
Is there any checklist I can run through to test it? Anything I can do to repair it?
It makes a weird „pling“ sound a second or so after it stopped.
No such thing as FDD "correctly detected during boot" - most BIOSes won't comply if FDD is broken, different than configured or not connected at all.
Have you cleaned heads? Doesn the head assembly move without problems? On these old FDDs I usually put a drop of silicone oil on the guide rails. Does the disk drive motor spin without problems?
Are there any electrolytic caps on the PCB?
