First post, by VioletGiraffe
Getting this error after restoring my system partition from backup, I don't understand what I broke and how to fix it. My "backup" is simply an archive of all the files on the disk. I reasoned that backing up the boot sector and partition table is not a concern right now since I'm not going to touch them, I just need the files and their contents. But after restoring from this backup, which means unpacking this archive back to the drive replacing all existing files, I get this error ("Non-system Disk Or Disk Error").
The partition is active:
The boot sector seems to be in order (makes sense, there's no way I could have broken it by simply moving the files around in Windows Explorer):
So what did I break? Some file attributes, perhaps? What is the bootloader checking for to conclude that the disk is not bootable?
