First post, by Eirle
Hi guys, I see that some people have problems trying to run TES Redguard in 3Dfx mode, I wanna run it in 3dfx using dgvoodoo 1.40+ in my old Toshiba Dynabook,a AMD K6-2 300mhz,with a S3 Virge MX 260 GPU,64mb ram,that in xngine mode is playable,well,I run dgvoodoo server application because Windows Me don't have connection between DOS and Windows as said in the readme.
I run RGFX.exe and I can see that it start, black screen appears, then it changes resolution and goes back to standard resolution and dgvoodoo and rgfx close, I've been trying to run in 3dfx mode a couple of weeks, I just wanna play it with the dgvoodoo in my pure Windows without DOSBox and VMware emulation.
I put dgvoodoo in Redguard directory, I don't know if texture cache in dgvoodoo setup is the use of my RAM.
I see a window open named gdvoodoo glide 2.43 (640x480), it stays black and then closes.
Why has God abandoned us?
Reply 1 of 4, by derSammler
Your S3 Virge MX 260 has 2 MB of video memory. There's no way to get dgVoodoo to work with that. Also, even the fastest Virge (which the MX isn't) is way too slow to even reach 10% of what a Voodoo card is able to render and the slow CPU doesn't help either. But since it's a notebook and you can't upgrade the graphics card, you have reached a dead end anyway.
Reply 2 of 4, by Eirle
Or I can install Windows Me in an Intel Celeron with integrated graphics, and then try to run it?
I can play Redguard in xngine without any problem, btw thanks.
Reply 3 of 4, by leileilol
Given how slowly laptop GPUs evolved, you'll need something more from the mid-XP era to be able to run dgVoodoo...
Reply 4 of 4, by Eirle
I can mount a pc, Pentium III, but I have no idea what graphics card use with it.
Maybe using Windows Me I can run dgvoodoo without any problem.
