First post, by alphac
How do u set file attributes under dosbox??
I have a very old dos 4 program that requires a file to be hidden, but there is no "attrib" command....
Thanks!!
Thanks!!
right-click and go to properties in Windows.
There is no support for attributes in DOSBOX ...
Mirek
this is ironic
Don't be so hard
Ironic?
Dosbox does support at least one attribute: Read-Only, hidden does not work however.
wrote:How do u set file attributes under dosbox??
An interesting discussion about attributes in DOSbox can be found here: Improving with internal command ATTRIB.
JAL
