First post, by thrawn235
Hello,
I have a really strange Problem with my Radeon 9800pro in conjunction with win98se.
The driver itself only gives me two options for resolutions 640x480 and 1280x1024.
Depending on the driver (ive tried several), widows either gives me an error when i try to choose any other resoltion or it changes it, but then i have that wiered scrolling effect. I only see a for example 800x600px area of the desktop, and if i move the mouse to the border it scrolls around.
Games don't change the resolution either.
I have tried Half life and Starcraft. both work but only une a small area of the screen (when i'm in 1280 mode)
Do you guys know whats going on there ? do i need a path for windows or a specific driver version.
Any help is appreciated.
Reply 1 of 5, by STX
In addition to the list of resolutions supported by the driver, there is a list of resolutions supported by the monitor. For a resolution to be usable, the resolution must be in both lists. Have you tried using an older monitor?
Reply 2 of 5, by thrawn235
Is actually an older CRT Monitor. I've used it with an even older Dos only PC (its connected to a KVM switch).
It can do all kinds of resolutions on the Dos one.
It seems like win98 detects it correctly. The device manager shows the correct name. so it must be able to read the EDID Data.
Is there a way to see what resolution the monitor reports as beeing capable of ?
Reply 3 of 5, by red-ray
My SIV utility has the Menu->Machine->Graphics panel which should do this and on this system I get as below.
file.php?id=70875
    64.49 KiB
Reply 5 of 5, by red-ray
thrawn235 wrote:
Any other ideas ?
From display properties/screen resolution if you select Advanced there should be a List All Modes, what does that list?
I don't have a 98SE system booted so I can't be precise about what to look at.
