First post, by seleryba
Hi guys.
I've found the Voodoo 1 card, it's probably ColorMAX VP-503. It's been recognised by Windows. But there's no image when I tried to run 3dfx demo or Quake II.
I found that two parts are missing. They're close to the VGA port and I suppose it's common part for VGA circuits. But what's that and what can I use to fulfil the empty pads? It looks like transistor or diode.
I've marked the elements on the generic image from the web and included it as attachment.
Could you help me please?
    392.22 KiB
Reply 1 of 4, by Horun
Those appear to be micro transistors or bridge type diodes and yes they are there. What is your main video card and are you using a short pass-thru (or a VGA extension) cable from the main vid card db15 to the voodoo input port ?
Reply 2 of 4, by dosgamer
The "D" means it's a diode. WTF are even "micro transistors"? 😁
Coppermine Celeron 800 @ 1.12GHz (8x140) - Asus P2B Rev. 1.12 - 256MB PC133 CL2 - Voodoo5 5500 AGP - SB AWE64 CT4520 - Roland SCC-1 - Intel Pro/1000GT - 1.44MB Floppy - ATAPI ZIP 100 - 120GB IDE - DVD-ROM - DVD-R/RW/RAM - Win98SE
Reply 3 of 4, by Horun
from the picture they appear to have three legs and look like micro smd transistors, yeah I know there is a D.
https://electronics.stackexchange.com/questio … igured-as-diode
Reply 4 of 4, by Tiido
Those are ESD protection diodes and lack of them shouldn't hamper operation, unless some trace is severed or a pad is ripped off where they are which is likely.
