First post, by elkbullwinkle
Hi, I have this 486 motherboard coming off Digital dec LPX 466d2 computer and it has a weird proprietary front panel connector. It would be nice to identify the pins, judging by the photos the computer didn't have anything special on the front panel, so I believe it should be speaker, reset (mb), power and hdd leds.
Funny enough there is a service manual available online if you google dec LPX 466d2, however it doesn't have the pinout, just says fp header.
I thought mb if anybody has the same computer, might check out the actual pinout.
I have attached the photos of the header and the board itself, sorry if they're too big.
The attachment J32 header.jpg is no longer available
The attachment board.jpg is no longer available
Cheers,
Sasha.
Reply 1 of 2, by PC Hoarder Patrol
Welcome to VOGONS Sasha.
Looks like DEC used this same header on a number of boards for basic panel functions - as you look top to bottom in your first pic it's RESET, HD LED & POWER LED and will be simple to check which pins are for which functions. If you look at this blow-up from the web (links below) you'll see the same header on the slightly later DECpc LPx 560
The attachment DECpc FP Header.jpg is no longer available
You can see the original sources at
http://jemascola.blogspot.com/2011/11/digital … pc-lpx-560.html
https://imgur.com/a/8ufkb from a Reddit article
Reply 2 of 2, by elkbullwinkle
Cool, thanks I will double check. I assumed they were different as that service manual that I've found mentioned a different modification with a different pin header.
P.S I've been reading for a long time, just haven't posted. Also gotta check notification settings, as didn't get an email re your reply.
Cheers. 😀
