First post, by CuPid
hello,
I recently got a very nice AT case with a 2 digit LED display. The small PCB gets three inputs : +5V (and ground), the turbo light, and a single wire for the turbo light status (that plugs to the mainboard). It worked for a while, but after I tried to change the setting, it stopped working : the LEDs stay unlit, and the turbo light status is not updated with the mainboard information anymore 😵
I made sure that the +5V is well on the wires, and I also checked the display segments with a multimeter (I made the segments lit very lightly by pluggin the anode and the catode with a multimeter), just to make sure that it worked.
But now I'm dry, and I don't know what else I could check to figure out what is wrong 😢
Any suggestion would be very welcome. Thanks in advance !
    228.67 KiB
    151.95 KiB
    in order : Turbo status, GRND, +5V.
    272.15 KiB
    Before it stopped working :(
I need a vacation.
Reply 3 of 3, by sf78
wiretap wrote:
Replace the two voltage regulators on the board. You'll have to remove the 7-segment display to desolder them.
In this case I would just cut the legs and solder replacement parts to stubs. You can add more solder to the PCB part if you want to make sure there's a good connection.
