First post, by Miphee
I have an IBM PS/2 57 486SLC2 without a power supply.
Since a used 79F3443/61G3410 PSU costs more than $100 + shipping I decided to just convert an existing PSU. I identified most pinouts of the original but not all.
I couldn't reliably identify the
white wire: is it -5V?
orange wire: is it PW_GOOD or +3.3V? I'd go with the first because it's a desktop 486.
purple wire: is it +5VSB? The AT PSUs I know don't have a +5VSB output so I'm puzzled: is this an AT or ATX power supply? Should I just convert an ATX power supply that has the +5VSB output?
Reply 1 of 14, by Miphee
Something like this?
    252.28 KiB
    ATX-IBM
Reply 2 of 14, by SSTV2
You can figure out an exact voltage rail wiring on any motherboard by checking continuity between a bus connector and the PS header of interest. There should be typical +5/12, -5/12 voltage rails, a +5V_SB might exist on that model, at least the IBM PSU, that I restored recently, had it.
Reply 3 of 14, by Miphee
I did that but the MCA bus doesn't have -5V. The same goes for the PW_GOOD and the +5VSB pins.
http://www.interfacebus.com/IBM_MCA_PinOut.html
Reply 4 of 14, by Miphee
Got this picture. Is the ON/OFF signal identical to the PS_ON signal of ATX?
    27.54 KiB
Reply 5 of 14, by Miphee
Model 33 has the same pinout.
    88.54 KiB
Reply 7 of 14, by Miphee
This is where I face the next problem: the computer is missing the power switch assembly.
I also don't know the pinout of header J19 to locate where the power button goes. I measured what I could.
    71.52 KiB
    Missing power switch assembly
    123.07 KiB
    Power switch assembly
    1.33 MiB
    J19 pinouts
    9.46 KiB
    J19 header
Reply 8 of 14, by Miphee
Correction, it's probably this switch assembly. I only assume because of the number of pins.
    120.96 KiB
Reply 9 of 14, by SSTV2
J19 connector is just a front panel header for activity LEDs, power switch and misc. stuff, that can be absent on your model. I think ON/OFF signal pin might directly connect to one of the J19 header pins, but you can bypass J19 for the moment. Connect ATX PSU voltage rails to J18 and J20 connectors accordingly (don't connect anything to the "ON/OFF signal" pin) and try to power it on by shorting PS_ON wire to ground, PC should turn on, unless it has some undervoltage protection circuit on the MB, comprising from OP-AMPs/comparators.
Reply 11 of 14, by Miphee
Alright, it's running now so I'm not going to use the ON/OFF signal pin.
It started with date and time error (00016300) but no options to set it. Any suggestions?
    574.36 KiB
    Set date and time error
Reply 13 of 14, by SSTV2
They are, believe me. My first PC was an IBM 8590 XP, imagine having to deal with their technical issues with no prior experience with PCs. Nothing was compatible with the system: PSU, MCA bus, RAM (parity only), cache RAM for HDD (proprietary), floppy drive, hard drive was SCSI and you cound't just swap it for a higher capacity quieter model, because it required a special BIOS setup partition on it, it had 2 sockets for 486 CPUs on a separate CPU board, so on and so on. You could also forget about the sound card option completely.
Reply 14 of 14, by Miphee
All's well that ends well. The 2.88 drive worked fine even though it was super dirty before cleaning.
Since I don't have a 50 pin SCSI HDD it's as far as I go for now.
Believe it or not I love these computers with all the proprietary parts that give me a hard time.
I still have parts missing, like the 212 MB SCSI HDD, the switch assembly, the back cover and all these parts cost an absolute fortune. I'd never spend hundreds of dollars for these, it's highway robbery. MCA sound card? No way for $900 that's crazy. But it's nice to own an IBM machine even if it's not 100% original.
Thank you for all the help. I'll spend more time with it when I get a SCSI HDD.
    1.79 MiB
