First post, by Shagittarius
Hey, just checking in to see if anyone has had any experience with this. I'm wondering if I add my GTX 1080ti to the last version of XP drivers that Nvidia released if I will be able to get it to run on XP. I know it won't be optimal but do you think it would run decently enough with the supported APIs for XP? Has anyone already done this or similar with another card? The lastest XP drivers supported up to the 960 so its not that far off from the 1080 time wise.
I'd like to do this because I dual boot with Win 10 on this machine and it would be nice to use the 1080ti when in windows 10 mode.
Just wanted to get experience/opinions before I waste time attempting to do this on already working builds.
Reply 1 of 10, by DosFreak
You can modify the inf for the latest XP drivers so that the 980ti works but AFAIK no one has gotten a 1080 to work. Rumour is that supposedly the earlier 10 model cards can be gotten to work but I doubt it and not much point if you want performance. If you want a newer card with a lower profile then may make sense.
Still using my 1080ti in my main desktop with my 980ti in my Q9650. Waiting for the release of the new graphics cards next year to see if worth buying, if so then I'll do some testing with the 1080ti with the Q9650.
With the 980ti on my Q9650 in Windows 10 Gears 5 runs at 30fps at 1920x1080, with D3D9 games in XP it's overkill but it works.
If I were you I'd put a XP compatible video card in there if you have enough room.
Make your games work offline
Reply 2 of 10, by Shagittarius
I currently am using a 780ti which is fine. I just wanted the better performance when running the Windows 10 boot. If I were to put both cards in there do you have a method for it automatically determining which card to use per OS? Hardware or otherwise? I don't want to use a switchbox if I can avoid it, I've already got mad switchboxes.
Reply 3 of 10, by DosFreak
I just change it in the BIOS and run another cable to my KVM then have another keyboard and mouse plugged into the computer. Works for me when switching between
GPU 1: Zotac Geforce GTX 980 Ti 6GB AMP! Extreme GDDR5 ZT-90507-10B PCIe (Windows 2000 w/ extended kernel and above)
GPU 2: Quadro FX 1300 128MB PCI (Windows 2000 Vanilla and below)
Reply 4 of 10, by Shagittarius
Thanks for the info, maybe i'll just stick with the 780ti. I guess it would be fun to run an SLI setup that way possibly too.
Reply 5 of 10, by agent_x007
If you want something more, buy Titan (Black or X), Black will work no problem (since it's 780 Ti with 6GB VRAM), and Titan X needs .inf addition to work.
Unless you re-write Windows XP driver side, to support Windows Vista/7 ones, Pascal on XP is just a dream.
Reply 6 of 10, by OMORES
Looks like it’s no longer a dream. I got a video from one of my Patrons (Brandon) and he managed to modify the last Windows XP driver, 368.81, to work with his GTX 1080 Ti.
You can see it in action at the end of this video: https://youtu.be/bkKFVcTehRs
I don’t know much more yet, but I’ll test the driver as soon as I get a compatible card. Right now it’s tuned for GP102 and GP104 chips, while the only Pascal card I have is a GP108. (GT 1030)
Classic Windows on modern hardware? Sure.
Reply 7 of 10, by Trashbytes
I can tell you that the modifications to the driver will be ...well black magic level of mods, likely taking a ton of files from newer drivers and modifying them to accept and work with XP.
Quite the thing to see a 1080Ti under XP.
Reply 8 of 10, by Shagittarius
A 780ti is more than enough to run any games you'd want to on xp. Is this just a to see if we can kind of thing?
Will the drivers utilize higher resolutions and refresh rates or will we still be locked to the features of the underlying os and supporting libraries?
I have a 1080ti I could propose for this im just curious what i would be gaining besides my initial desire dual boot reasons which have lessened since the original post.
Congrats in getting it running though.
Reply 9 of 10, by Trashbytes
Shagittarius wrote on 2026-09-26, 17:04:
I have a 1080ti I could propose for this im just curious what i would be gaining.
Watch the Video, looks like you can create custom resolutions much like you can under Win 7 and UP via the Nvidia Control Panel. I kind of want the driver myself so I can bench the hell out fo it and see what works and what needs more tinkering with.
I also wonder how they managed to bypass the nVidia software lock that prevents Installing the newer drivers even with inf modding.
Also pretty much most of what we do in the Retro scene is just to "see if we can" these days, aint much else to actually do than getting hardware to operate under conditions it was never built for, as for benefits .. there is none but shit a 1080Ti under XP is damn cool to see.
Reply 10 of 10, by agent_x007
I'll let you cook it some more...
If possible (on next video), please show you moving GPU-z window (that shows "GTX 1080 Ti" and "XP" driver loaded), in front of 3DMark 06 benchmark running in window mode 😉
