FreeDOS 1.3 RC2
First post, by DosFreak
https://sourceforge.net/p/freedos/news/2019/1 … freedos-13-rc2/
We are moving toward the FreeDOS 1.3 release. FreeDOS 1.3 Release Candidate 2 is now available for download. Please help us test this new version!
A big feature in FreeDOS 1.3 will be booting into a LiveCD version of FreeDOS. You can test this by downloading FD13-LiveCD.zip, which contains FD13LIVE.ISO. This media is similar to the LegacyCD. However instead of relying on the BIOS floppy disk emulation, it uses SYSLINUX and MEMDISK to boot an emulated floppy disk. Along side support to perform a Plain and Full installation FreeDOS, this media is also able to run FreeDOS live from RAM or CD (depending on computer system and hardware) without installation to an internal hard disk drive. You can also download FreeDOS 1.3 RC2 in "Full" and "Lite" versions, and a "Legacy" CDROM version that is set up to let the CDROM boot on older hardware. Most users should try the LiveCD version. You can download the new FreeDOS 1.3 RC2 from the FreeDOS file archive at ibiblio.
Make your games work offline
