First post, by p6889k
I have X-Wing Collector's CD-ROM and I'm unable to save sound config. I install the game, launch sound setup, select custom sound setup and advanced, I pick my digital and music sound configuration and when I try to exit I get a message "Current configuration is incomplete and cannot be saved."
Here are the settings:
LucasArts Sound Setup Utility Ver. 2.0
Music: General Midi
Port: 330
Digital Sound: AWE32
Port: 220
IRQ: ?
DMA: ?
Stereo Reverse: 0
When I choose Test Digital and Test Music all sounds/music plays correctly.
The IRQ and DMA selection is grayed out with question mark, hovering over the question mark says: "IRQ/DMA not configurable in this program".
I've tried launching sound setup in DOS 7 and also DOS window in Win98 with same results. I also tried picking different sound settings. The game itself works fine, I just can't configure sound. Is there perhaps a file I can edit manually to set sound config?
Sinclair ZX Spectrum 48k, 48k+, 128k, +2
Amiga 1200, 68030/40mhz
386DX/33, ET4000, SBPro2, MT32
Dual PPro/200, Millennium II, Voodoo 2, AWE32, SC-55
etc.
Reply 1 of 3, by p6889k
I made some progress, if I let the config utility autodetect, it will select SB16 with correct IRQ and DMA. If I then try to change SB16 to anything else, IRQ and DMA get reset to ? and is greyed out. So basically, I need to stick with autodetect.
etc.
Reply 2 of 3, by HunterZ
Are you trying to run the sound setup from the CD-ROM instead of installing to the hard drive and running it from there?
Reply 3 of 3, by p6889k
I installed the game from CD and then launched sound setup from HDD.
etc.
