First post, by KainXVIII
Pixelation in Omikron is still there with WIP69
75.53 KiB
379.7 KiB
Reply 1 of 13, by KainXVIII
Dege wrote:
How to reproduce this one? Giving the game a quick go it worked fine for me. Selecting a special resolution or sg like that is needed?
Steam version, these settings. Bug occurs only when subtitles or game UI shows on screen.
53.76 KiB
50.98 KiB
405.51 KiB
Reply 6 of 13, by Dege
I've just checked out the GOG version, and indeed, there is pixelation.
The original game rendering is modified by patch.dll, and the technique used conflicts with dgVoodoo's resolution scaling process.
But luckily, a little patch helps:
http://dege.fw.hu/temp/OmikronNomadSoul_patch.zip
I assume the Steam version has the same version of patch.dll, so this patch can be used together with that too.
Reply 7 of 13, by KainXVIII
Dege wrote:
I've just checked out the GOG version, and indeed, there is pixelation. The original game rendering is modified by patch.dll, an […]
Unfortunately, this patch does not help Steam version. But i can send you some dll/exe files from steam version if this helps 😎
Reply 9 of 13, by KainXVIII
Dege wrote:
It's a pity...
Does the steam version has patch.dll? If it doesn't then I could only debug the game itself to find out what to modify. 🙁
Yes, it has.
26.86 KiB
Reply 11 of 13, by KainXVIII
Dege wrote:
Ok, then let's attach patch.dll here plz, I may be able to patch it blindly...
Here you go!
patch.7z
43.91 KiB
71 downloads
Reply 12 of 13, by Dege
Ok, here is the patched one.
Does it work? Won't the steam updater overwrite it at once, detecting the file changed?
    patch_steam.zip
    50.96 KiB
    83 downloads
Reply 13 of 13, by KainXVIII
Yes, its working now!
Don't think that steam will overwrite the file (unless i tell him to) or game will be patched in near future (which is highly unlikely now).
