First post, by bearking
Hi to all of you!
Wish you all a happy Christmas!
I need a little bit of help from you identifing an ald IBM cpu, I guess it's some kind of 386, but I couldn't find any specific info. Maybe it's not even a cpu, I can't tell.
Here is a picture of it, maybe someone has this in collection, or knows about it.
1.29 MiB
LE: on the top row it's written: 63G9568
Thanks for any info!
Reply 1 of 3, by Anonymous Coward
CPU world would probably be a better place to ask, but what I can tell you is that it's almost certainly a 486DLC chip. It's not an SLC because it has 132 pins. More than likely it's a DLC2 or DLC3. I don't think I've ever seen a single clocked DLC (but they exist?). Also no idea on the clock speed. DLC2s are usually 66MHz. The DLC3s usually 60 or 75MHz. The 100MHz part is relatively uncommon.
Reply 3 of 3, by douglar
"IBM 14 PQ" seems to suggest it is from the Blue lightning family.
"M52" = Manufactured Week 52 1993
Too bad the model number is obscured. Best I can make out is 63G250? which is 1) a wild guess and 2) looks similar to the model numbers seen on some of the clock tripled BL chips.
http://www.cpu-world.com/info/IBM-parts.html
