First post, by ThatRetroDude
Hi everyone.
I recently bought a Pentium 1 system with a flat DS1287 clock chip. I saw that there was space to solder in a CR2032 battery holder, so I did. But it's not working. It still says 'CMOS BATTERY LOW' with a brand new CR2032. Am I doing something wrong or is that space just unusable?
Reply 1 of 7, by ThatRetroDude
note: The DS1287 is unmodded and the CR2032 is soldered directly to the board. (The board had an unpopulated area where a coin cell battery could be soldered in place).
Reply 2 of 7, by zyga64
You can replace DS1287 with DS12885 and make sure that (+) of the battery goes to Pin20 of the IC (VBAT). There may be empty place on PCB (for diode) between those points - to prevent inverse polarity.
And for DS12885 also X2 part must be populated - it is 32.768 kHz quartz - same as used in electronic watches.
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 3 of 7, by ThatRetroDude
zyga64 wrote on 2019-12-27, 22:11:
I have tried to desolder the DS1287 but I was unsuccessful. I’m pretty much at a standstill with this machine because I cannot get the DS1287 out.
Reply 4 of 7, by texterted
There's a solution here http://www.mcamafia.de/mcapage0/dsrework.htm
Maybe it'll help?
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Reply 5 of 7, by rkurbatov
If you don't have desoldering station (like me) try using injector needle. Melt an alloy and put needle into the hole, rotating it. I have manual sucker pump but it simply doesn't work. I managed to desolder one side of the IC, then broke another row of pins and desolder them too. That was painful experience.
Just curious. They did a stupid thing with barrel batteries, ruining a bunch of motherboards, so proposed instead IC with a battery inside that cannot be replaced! Why not just use socket for every IC? Replaceable CR2032 lives 20 years since then. As usual, we behave wisely only exhausting all other alternatives.
486: ECS UM486 VLB, 256kb cache, i486 DX2/66, 8MB RAM, Trident TGUI9440AGi VLB 1MB, Pro Audio Spectrum 16, FDD 3.5, ZIP 100 ATA
PII: Asus P2B, Pentium II 400MHz, 512MB RAM, Trident 9750 AGP 4MB, Voodoo2 SLI, MonsterSound MX300
Reply 6 of 7, by chacha
I have this MB and had the same problem.
For future readers, easy fix: https://github.com/necroware/nw12887
There is already manufactured one on ebay, they for perfectly !
Reply 7 of 7, by rkurbatov
chacha wrote on 2025-02-25, 23:08:
Necroware has found a new method of much simpler cleaning of the original chips with hot air - https://www.youtube.com/watch?v=ecTZtZhE9bI&t=762s
You can try it first before buying a replacement.
