First post, by Mephisto
here is a Problem that i never realized until now:
1.st, here are my Mount Command, that are starting with the DOSBOX (0.61 & 0.62)
mount c: d:\games\pure_dos
mount d: e:\ -t cdrom -ioctl
mount e: f:\ -t cdrom -ioctl
c: is my mounted Directory on the HD
d: is my REAL CD-ROM
e: should be my Virtual CD-ROM
but, when i run the "mount" command on the DOSBOX, it shows me only:
Drive C is mounted as Local directory d:\games\Pure_dos
Drive D is mounted as CDRom
Drive Z is mounted as Internal Virtual Device
And now my Question: how can i Mount the Virtual CDRom to be Drive "e".
or did i do something wrong ???
The Virtual Drive a Daemon tools Virtual - CDRom.
Reply 1 of 4, by gulikoza
DOSBox mounts my DaemonCD drive just fine. Are you sure have mounted an image in Daemon?
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
i think you should use the option -usecd number
as you have more than 1 cdrom in your pc.
Water flows down the stream
Reply 3 of 4, by eL_PuSHeR
Even if i can mount several cd-rom drives (including a daemon tools virtual one) without using -ioctl parameter, you should heed Qbix advice.
Reply 4 of 4, by Mephisto
WAS MY FAULT:
I wrote in the cfg file "MOUND" instead of "Mount"
but , thanks for help !!! 😊 😊 😊
So i think this thread could be closed
