DosBox on Macs....
First post, by Guest
Which (if any) version(s) of DosBox run on 10.1.5? I know that .62 doesn't, and I haven't been able to use .61, though I might just be doing something wrong. Any help would be appreciated.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
0.62 probably will as long as you compile it yourself.
Water flows down the stream
