First post, by guest
I'm having trouble with dosbox-0.62-4 and Fedora Core 3.
It worked fine on FC1, but when I upgraded to FC3, it wont run 🙁
Any ideas?
Thanks.
Any ideas?
Thanks.
What about more details? When it crashes, what errors etc.
Mirek
I just did a fresh install of Fedora Core 3 😀
Then I installed the "dosbox-0.62-4" RPM that worked fine on Fedora Core 1 and this is what happens:
[root@Lucy mugga]# dosboxSegmentation fault
Thanks for your help
Why don't you try to compile your own version?
It's as easy as: download the sources and extract them and issue the following command:
./configure && make && make install
I use dosbox-0.62-4 on FC3 and it works fine here.
I used it on Fedora Core 2, but as soon as I updated to FC 3 dosbox started having problems.
I type dosbox from the command line and I get:
*** glibc detected *** double free or corruption: 0x0ada6f88 ***
Aborted
This spark any ideas from anyone?
read the 0.62 bugs thread second page.
Water flows down the stream
