First post, by Nocturnus
Hi. Can you try this game? I don't know why it doesn't work. Thanks!
The demo seems to be broken. I got a 'log' file containing the following:
- D3D Info ----------------------------------------------------------------Video Adapter : NVIDIA GeForce GTX 1060 6GBDriver : nvldumd.dllVersion : e0c80Max Texture Width = 16384, Height = 16384Screen resolution setted to 800x600lpD3D->CreateDevice(...) done.- D3DDevice Info -----------------------------------------------------------Available Texture Memory : 4092 MbPixelFormat : D3DFMT_R5G6B5------------------------------------------------------------------------Load: gfx/interface/co_logo0.jpgLoad: gfx/interface/co_logo1.jpgg_ParticleLibrary.RegisterClass()g_ParticleLibrary.CreateTextures()BASS_GetVersion()BASS_Init(...)Unload: gfx/interface/co_logo0.jpgUnload: gfx/interface/co_logo1.jpgProgram terminatedError: Can't load music : msx\bld5trlo.IT
It's a pity, I was curious of a game playing an Impulse Tracker module as music.
Could be an OS incompatibility issue (with how it tries to read files from its data file) too. Works fine in dgVoodoo at any rate (if you give it wrong version bass.dll, it will disable sound):
Yes, it seems to be a error with .IT music file / bass.dll. After I replaced the bass.dll it works fine but (as ZellSF said) no sound.
Well, you can't had them all.
Thanks for the info!
So I downloaded that demo you linked to. Must be a Windows 10 issue? Works in Windows 7 Pro 64 without issue and without dgVoodoo.
Yes, I'm on Win 10. Good to know. Thanks!
