First post, by user33331
- Member
They look same so can I mix front panels ?
-Live!.
-Audigy 1,2 zs.
-X-FI.
I have never actually used these front panels:
What do they do in simple terms ?
Do they have any real use ?
-Live!.
-Audigy 1,2 zs.
-X-FI.
Live! and Audigy 1 panels - interchangeable.
Audigy 2 - only Audigy 2 series. EDIT: Compatible with X-Fi panel too.
X-Fi - PCI and PCI-E card panels are incompatible between each other.
Remote control, sound volume control, audio inputs and outputs, firewire port.
For gaming? Headphones jack and volume control. Playing songs via player remotely. Maybe SPDIF output, if you need to record your footage from another computer.
i have the live drive, audigy and audigy 2 front panels and they are not interchangeable.
