First post, by banator
Hi
I am trying to run an old game, that I once wrote in turbo pascal. The game uses quite a lot of assembler for graphic manipulation. The game is called banator. And its a small two screen jump and run.
So far the game starts up and loads the first initial graphic, but then it stops.
It doesn't display any sprites only the background.
As far as I rember, I was modifing some interupts routin, can this be a problem for dosbox?
Is there someone I can send the game to and he can take a look at it?
Please email me: banator at suvi . org
Reply 1 of 1, by wd
Rank DOSBox Author
DOSBox Author
You can post your program (maybe sources as well) here on the
board, if it is not too big (try the development forum if attachments
don't work here). Maybe somebody finds out why it doesn"t run.
wd
