First post, by AngelRF
Hi, I have problems finding drivers for Kingston KNE2021LC.
I did a intense google search, but I only find old links that doesen't work. network-drivers.com apparently has it, but when I click the donload button of the driver it downloads a stupid driver utility.
I'm very frustrated because I tried before another driver for the EtherX but it just freeze the 486. And I don't exacly know if the KNE2021LC is EtherX (probably not).
So it will be fantastic if someone can give me the drivers (i think is a whole floppy), or a working download link. Thanks for your help.
PD. What is wrong with network-drivers.com? All the download links downloads a driver utility (DriverEasy_Setup.exe) and not the actual driver itself. I obviously can't run a modern driver utility for Windows in a DOS 486 machine.
Reply 2 of 4, by zyga64
I have Kingston KNE-2121+. I was able to download drivers from web archive
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /ES1370
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 3 of 4, by AngelRF
So much thanks! And a little question, I have to run the QSTART.EXE and install the driver or I just need to load the packet driver for mTCP to work?
Reply 4 of 4, by zyga64
I'm using network cards in DOS with Etherdfs. It only needs packet driver.
Works like a charm, but only with default IRQ card settings. Not only with this card - I observed this behavior with few of them.
