First post, by ael1964
I`ve installed on AMD 2400 XP+ with 1 GB RAM,Geforce 5700 LE and 200 GB SATA HARD DISK with Win XP PRO SP2 dosbox and I made all the needed configuration to run games under dosbox,but c: drive under dosbox has only 100 MB free space,who do I make additional free space?
I`ve tested some games with 0,63 versions and all worked fine!But I can`t install more cd roms games than one because of free space.
Give back our child memories....!DOS games for ever!
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
did you happen to read the documentation of dosbox ?
if not do so.
there are even examples in it on how to increase the diskspace.
Water flows down the stream
