First post, by najls
Hi!
Beginner at retro hardware, hardware in general, and new to Vogons (first post, hooray), so apologies in advance if everything beyond this line comes out stupid.
So I have this Pentium 75 computer from around 1993 that I would like to use for DOS/Windows 95 gaming. I also have a 133MHz Pentium processor just lying around and I thought, as one does, it would be neat to try and pop that in instead and maybe get Curse of Monkey Island running. It might run now for all I know, havn't really tried it. Really just an excuse I made up to get to switch something out and now I believe it myself. Beside the point.
The mobo is a Microstar MS-5118 and according to the manual it "Supports Intel P54C - 75 MHz/90 MHz/100 MHz/120MHz/133 MHz" (then on another page it shows DIP switch settings for clock speeds up to 166MHz, but I'll ignore that because confusing). From what i gather the processor I intend to install, a Pentium 133 SY022, is built on the P54CS microarchitecture. This makes me a bit hesitant, because I have no idea if that has any significance - P54C vs P54CS. I mean, it's still Socket 7 and the clock speed should be supported.
My question isn't really if it will work, but rather, what's the worst that can happen if it doesn't?
Reply 1 of 21, by Vynix
It should work, after all, just set the jumpers accordingly. Though beware because some motherboards can act fussy with fast CPUs, though it seem to be a rare occurrence.
Reply 2 of 21, by mpe
There is no practical difference between P54C and P54CS as far as motherboard compatibility is concerned.You'll be fine.
Blog|NexGen 586|S4
Reply 3 of 21, by dionb
The worst that could happen would probably involve wounding yourself or a loved one on a pin of the old CPU, the wound getting septic and dying in slow agony. However that isn't exactly very likely 😉
All you need to do is swap out the CPU and change the relevant jumpers. Currently bus speed is set to 50MHz, that needs to go up to 66MHz. Theoretically you also need to change the multiplier jumper from the position for 1.5 to the position for 2.0, but in this case it won't matter as the SY022 P133 is multiplier-locked on 2x anyway.
Everything else can remain the same. The only outside corner case you might hit is that cache or RAM chips can't handle the faster 66MHz bus speed and the system becomes unstable. You can check for what they are rated for by looking at the last digit on the chips' model# row. On the RAM chips it will be -7 or -6. -6 implies 60ns and is fine for 66MHz (and above), -7 implies 70ns and is theoretically good up to 60MHz, but not 66MHz. It will probably work, but in case of issues, it's the first thing to look at. For cache the marking to look for is -15. That's 15ns (cache SRAM is faster than DRAM, that's its job), and is good for 66MHz. Anything above that might not work.
Reply 4 of 21, by Horun
najls wrote on 2020-01-30, 21:33:
The P54C was 3.3v and 50uM die type, the P54CS was 3.3v and 35uM die type. Basically just smaller sized transistors inside but functionally and electrically the same. You should have no problems swapping them. Just make sure you install it correctly and pull the power before swapping. Use a heatsink + fan for longer life.
edit: worst that could happen is you try to install it in the socket wrong or have power applied when you swap....
Reply 5 of 21, by The Serpent Rider
You can't install any Pentium CPU wrong side, including Pentium Overdrive. It's idiot proof, although not excessive force proof.
Reply 6 of 21, by Horun
The Serpent Rider wrote on 2020-01-31, 04:36:
Yeah well I have seen the results of somone swapping Pentium cpu while board was in a case and it was not right but they didn't know it. One corner was up but they powered it anyway. You can guess the result.
Reply 7 of 21, by dionb
Whenever somebody designs something to be more idiot-proof, we just get better idiots...
Reply 8 of 21, by najls
Yeah, I'd say this is the only part I'm sure I won't mess up 😀
dionb wrote on 2020-01-30, 22:01:
Will be stocking up on antiseptics though.
Very good advice! Will make sure to check this out. Thanks!
Horun wrote on 2020-01-31, 04:28:
Check! I'm using a heatsink and fan for the P75 right now and I even put on cooling paste, but I kinda had the feeling that was a bit excessive. Was it? 😀
mpe wrote on 2020-01-30, 21:40:
That is pretty much what I wanted to hear. Learning about things is nice. Thanks!
Reply 9 of 21, by imi
well, I've seen a socket 7 CPU inserted into socket 370 before...
Reply 10 of 21, by SirNickity
It's true. This happened to me.
najls wrote on 2020-01-31, 07:39:
The HSF situation on older CPUs like this are a little more forgiving than what we have now. No, you don't absolutely need thermal paste - but, if you have some of the plain white grease that you get with any passive cooler ever, it doesn't hurt to add a dab of it. Not too much. If you mount the heatsink and your CPU looks like a burger ad, you've gone too far. Just a thin thin layer will do.
The other common question is "how much is enough cooling?" In some cases, just a heatsink is OK. Usually you need the fan. It depends on several variables, like the profile of the heatsink, airflow in the case, ambient temperature, etc. Here's my definitive test: When the system has been running for five minutes, give the heatsink a light touch. Is your finger OK? Then your cooling is adequate. Better yet, if it's warm but not uncomfortably hot, then you're all set.
Reply 11 of 21, by shamino
From what I've read I guess some of them were locked, but not all. My SY022 isn't locked.
If you get it working at 133MHz then try changing the jumper to 2.5x and see what happens. SY022 was a late revision CPU so if yours isn't locked it will probably run easily at 166MHz.
Reply 12 of 21, by Baoran
Only thing I am bit confused about is that you said it is from around 1993, but pentium 75Mhz was released in 1994 as far as I know and that microstar motherboard seems newer than 1993 to me as well.
Reply 13 of 21, by dionb
shamino wrote on 2020-02-01, 05:51:
Some SY022 CPUs unlocked? You live and learn 😉
...except this is an So5 board, so no BF1 multiplier jumper. There isn't a 2.5x setting, to do that you'd have to mod CPU or socket to conect BF1 pin to Vss/GND.
Reply 14 of 21, by najls
SirNickity wrote on 2020-01-31, 20:42:
I went with the heatsink and fan and some cooling paste. There's no additional cooling in the case, but this seems fine. Thanks for the pointers!
Might give that a shot, though I'm not actually sure I need that much speed 😀 I actually havn't benchmarked it yet either. Any suggestions for realiable software to use (in Windows 95)?
Baoran wrote on 2020-02-01, 10:00:
I may very well just be wrong on this point. I've been having a hard time finding info on the mobo. It may very well be from 1994! Not sure if the P75 was the processor it originally came with either.
Reply 15 of 21, by NostalgicAslinger
I have here a late produced (produced in 2001!) Pentium 133 SY022 stepping with free 2.5x and 3x multipliers! Also runs fine with 200 MHz and the default VCore of 3,3V. Why are some SY022 unlocked, because I have thought that all are locked? I also had a P133 (produced in 1997) with the same stepping that gaves a Blackscreen, after setting the multiplier higher than 2x.
Reply 16 of 21, by mpe
As far as I know all Pentium are unlocked except for overdrives.
Intel started locking CPUs in 1998 (Pentium II).
Blog|NexGen 586|S4
Reply 17 of 21, by dionb
mpe wrote on 2020-05-06, 20:19:
There are definitely locked Pentium 133 SY022 CPUs out there - those things didn't get a reputation for nothing. Less certain, but I recall some MMX CPUs also didn't want to accept some multiplier settings.
In fact here's one of the engineers who worked on it giving a not very specific apology 😜
https://forums.anandtech.com/threads/pentium- … 70/post-4349447
https://forums.anandtech.com/threads/pentium- … 70/post-4351373
Reply 18 of 21, by Anonymous Coward
Yeah, I'm pretty sure they actually started locking chips in 1997. As the poster above stated, it was PMMX. I remember some PMMX chips were locked and others not. Maybe original Pentium chips produced in 1997 were too, but this is new to me.
Reply 19 of 21, by Intel486dx33
I am ready to start testing the Pentium 133 too.
I am currently using a Pentium 75 in an Intel 430vx motherboard.
I am going to put the Pentium 133 in an Intel 430tx motherboard.
