First post, by Warpath
I get an odd error on DOSbox.
I use the source and compile my own Dosbox, as soon as I install and run, I get a black window and Dosbox completely freezes (jus a black window shows up, nothing on screen, not even text). I can 't even kill -kill the process. Yet if I run a second time after the freeze (while the frozen one is still in memory) it runs, but slow as molasses (understandably why). I'm using a AMD 2400+, 768MB Ram, Linux Kernel 2.6, and latest NVidia Drivers. Anyone know about this problem?
Reply 1 of 1, by helper
try a different kernel version ?
(if you happen to have 2 installed)
