First post, by DosFreak
 - l33t++
https://github.com/SuperIlu/DOjS/releases
Fixed typo in the GetXRotateMatrix() functions. Sped up several 3D math function by implementing them in C (native JS functions […]
Sped up several 3D math function by implementing them in C (native JS functions still available by prefixing 'N').
Added Bitmap.DrawAdvanced() for scaled bitmap drawing.
Fixed CTRL-C handling on FreeDOS, now copy & paste works there as well.
You can now pass command line parameters to your scripts.
Added String.startsWith() and String.endsWith() from MDN.
Added HSBColor() to native API.
Fixed SizeX() and SizeY() after using SetRenderBitmap()
Added joystick functions.
Fixed "new sketch" template.
Added 3Dfx/Glide support for Voodoo1/2/3/4/5/Banshee/Rush
Improved error reporting from Allegro
Added automatic fallback to 24bbp when 32bbp are not available
Fixed the remote logviewer and some examples
heh, mabye js-dos can be ported .
