Power supply load test?
First post, by maximus
What's the best way to put a load on a power supply for testing purposes?
My understanding is that power supply testers just test voltage levels while putting very little load on the unit. I would prefer something that also consumes 150 to 200 watts.
I used to use a beater Pentium 4 motherboard to test power supplies. This worked okay, but the setup was more complicated than I would have liked (board, CPU + cooler, RAM, video card, and power button versus a hypothetical self-contained unit). It also didn't allow me to fully test 24-pin connectors or PCI-e connectors. The board eventually developed bad caps (could this have been from testing bad power supplies?), and I would feel stupid buying a new old motherboard just to replace it.
Any recommendations?
PCGames9505
Reply 1 of 6, by Unknown_K
Depends on what you need I guess.
Old supplies need to be tested on the 5V section because that is where the most load will be.
New supplies need to be tested on the 12V section for the same reason.
If you test a new supply using a 150W load on 5V it will always fail unless you have a 1000W+ beast (most general supplies seem to be 120W max on the combined 5/3.3V).
I use a generic tester on standard ATX supplies (some old OEM supplies are wired differently). Newer testers show actual voltages on an LCD screen (plan to get one sooner or later). You can connect an old power hungry HD drives that doesn't work properly for a load while the tester is on.
Any newer supply should shut down if voltage is too high/low else you should not be using it to begin with. Even the old crap AT supplies will shut down if you have a dead short somewhere.
Caps go bad from heat, use, and bad design especially during the Athlon XP and P4 era, deal with it.
Reply 2 of 6, by ATauenis
Some Socket A boards like Gigabyte GA-7VA utilized 5V channel for CPU power stabilizer. Athlons and Durons were also hungry like P4, but boards making much load on 5V instead of 12V. So S462 is a good platform to test PSUs.
But the only scientifically-correct way is to make real current on all channels like listed on label. It may be do like stress tests of diesel locomotive generators. 😀 By using HUGE resistors and water cooling (bathtub-size boilers).
2×8080, 2×Soviet ZX-Speccy, 1×MacIIsi, 1×086, 1×286, 3×386DX, 1×386SX, 2×486, 1×P54C, 8×P55C, 7×Slot1, 5×S370, 1×SlotA, 2×S462, ∞×Modern.
Reply 3 of 6, by aaronkatrini
There is this guy called Falco75 and he is a kind of celebrity here in Italy. Mostly known for his contribution in the Italian forum of TomsHardware.
He also does youtube: https://www.youtube.com/channel/UCg8YjbZgHqv784ZVXu7y8nw
He manages to check about every available powersupply on the market and gets to test them in different aspects.
Voltage, ripple, noise levels, components used inside, circuitry ...etc.
In his youtube channel you can see he built a "box" with what I think are Halogen Lamps (not sure?) and he uses them to put load on the PSU voltage rails (3.3, 5, 12V).
I think he once wanted to make available the components inside his "magic box" but I don't know... I will check and will update if I find more info. 😀
Reply 4 of 6, by SirNickity
Yep, light bulbs are a great load for testing. If you can still get resistive elements anyway...
Reply 5 of 6, by texterted
I suppose you could rig something up using car headlight bulbs. At least for 12v rails.
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Reply 6 of 6, by chrismeyer6
I'm wondering if you can use a automotive battery load tester to test a power supply most of them do 12v/6v.
