First post, by jasa1063
I just put together a K6-III+ build and wanted to share a few things I found out along the way. The PC Chips M599LMR uses the SIS 530 chipset and while not top of the line in terms of Super 7 chipsets, I have found it to be very capable in the right configuraiton. I have the K6-III+ running at 600Mhz at 2.1v. This has been extremely stable and there are no issues so far running Windows 98 SE. I found the following cooler on Amazon for around $20, it is all copper and makes for reaching 600Mhz a breeze.
https://www.amazon.com/StarTech-com-60x10mm-S … 81970507&sr=8-1
The system has 512MB of PC133 CAS 2 memory, a Sound Blaster 16 ISA sound card, and a Voodoo3 2000 PCI graphics card. The onboard modem, sound, and video have been disabled. I also have a IDE to SATA adapter with a 120GB SATA SSD.
https://www.amazon.com/StarTech-com-Drive-Opt … 81971022&sr=8-3
The onboard video does not completely disable. When you switch the primary video from AGP to PCI in the BIOS setup, it will not allocate any memory to the onboard video adapter. You also need to disable it in the Windows Device Manager. After doing that I had no issues. The DOS compatibility is really good and it runs a lot of Windows 9x games. This has made for a really nice Super 7 system. The M599LMR motherboard was chosen because it is not the most sot after Super 7 board and therefore much more reasonably priced. I just wanted to share my experience if someone else want's to do a Super 7 build and save a few bucks on the motherboard in the process.
Reply 1 of 9, by Joseph_Joestar
That's pretty much the perfect build for Win98 and DOS gaming. Congrats!
With the Voodoo 3 you get 8-bit palletized textures and proper table fog, which ensures that early 3D accelerated games look as intended. And that K6-III can be slowed down as needed using SetMul which makes it a breeze to properly run older, speed sensitive DOS games like Wing Commander.
The only thing that rig might not handle so well could be 640x480 FPS games like Quake and Duke3D running in software mode. Have you done any performance tests with those?
Reply 2 of 9, by jasa1063
Joseph_Joestar wrote on 2020-02-17, 21:16:
You are correct in that Quake only gets about 27 FPS at 640x480 in software mode. I have not benched Duke3D yet. Quake was the really the first game that used the FPU in the Pentium series to the max. Without a pipelined FPU, the K6 and Cyrix 6x86 performed poorly in comparison.
Reply 3 of 9, by Joseph_Joestar
That's still pretty decent. Back in the day, I played through the entirety of Quake on my Pentium 133 at 400x300 or some similarly weird resolution, getting barely 10-15 FPS. Still managed to finish it... somehow.
BTW, does your Voodoo 2000 exhibit any artifacting in DOS resolutions like 320x200? This issue seems to crop up on some systems (including mine) but not on others.
Reply 4 of 9, by jasa1063
Joseph_Joestar wrote on 2020-02-17, 22:16:
Thankfully, no it does not. That is usually from the chip getting too hot for too long and that is one the results. The chip is damaged by that point and there is no fixing it other than to replace the card. That is why it is a good idea to put an after market cooling solution on a Voodoo3 2000. I have one on mine and it should keep it running good for years. The Voodoo3 3000 and 3500 usually did not have that issue because they contained a much larger heatsink.
Reply 5 of 9, by rmay635703
Those chipsets overclock to 133mhz easily
Worth a crystal change
Reply 6 of 9, by jasa1063
rmay635703 wrote on 2020-02-17, 23:42:
I have heard the main issue with that on the SIS 530 is being able to completely disable the onboard video. Only a few boards had a jumper to do that.
Reply 7 of 9, by Stedman5040
This board may be able to run at 133Mhz fsb. The option may be available inside the bios set up for the board. It is not available by jumpers on the board itself. I have a Gigabyte GA 5SMM board and that runs at 133Mhz fsb no problem with a K63+ cpu. So 133 with a 4.5x multiplier. Also the memory performance of the SIS530 chipset is not great, but running at 133Mhz and using the tweaks available through WPCREDIT you can match the performance of the Ali5 and Via MVP chipsets running at 100MHz. WPCREDIT and WPRSET are available at Falconfly.de or at K6plus.com . The pcr file for the SIS 530 chipset should also be available at K6plus. Even enhancing the memory performance by using the tweaks available through WPCREDiT should give you more at just 100MHz fsb. There is a big thread at K6plus on the SIS530 chipset enhancements.
Stedman5040
K6 III+ 500
Epox MVPG2
512Mb Hynix CL2 SDRAM
40MB WD HDD
Creative GeForce2 Ti
CMI8738 Sound card
Reply 8 of 9, by jasa1063
Stedman5040 wrote on 2020-02-18, 14:30:
Stedman5040
That is great info to have. Thanks for the heads up and I am definitely going to take a look on k6plus.com.
Reply 9 of 9, by jasa1063
Just doing a quick followup on how this system has worked out. The ability to change the the K6-III+ multiplier has been a real life saver. I had several programs that would give the dreaded runtime error 200, because they were compiled with Turbo Pascal and the flawed CRT unit. Putting the multiplier to 2.0 completely fixes this. Disabling the L1 & L2 caches runs the system about the speed of a low end 386. Anyone needing to run a spectrum of software from the 386 to Pentium era would be well served with a setup like this. This rig really turned out much better that I had thought it would:)
