GUS memory
First post, by wotschie
Is there a possibility to increase the GUS memory. I'm using Impulse Tracker and sometimes 1MB simply isn't enough 🙁
Maybe there is an entry in the dosbox.conf, but I couldn't find any.
Thanks
Marco
Reply 1 of 2, by jal
The original GUS (and other GF1-based cards like the Max and the Advance) has support for 1Mb of memory, not more. IT on DOS with a GF1-based GUS cannot access more than 1 MB of memory either - this is not DOSbox related. Only the GUS PnP (AMD Interwave-based) has a larger address range, 32 Mb can be installed on this card. However, since the PnP hasn't had that much DOS support, I doubt that it will be supported by DOSbox in the near future.
JAL
Reply 2 of 2, by wotschie
OK, thank you for clarifying.
