First post, by ruthan
- Oldbie
Hello,
i tried to setup Bochs DOS machine.
http://bochs.sourceforge.net/doc/docbook/user/
Im able to install and make DOS 7.1 booting , but otherwise whole experience is not good. Its someone else able to setup really something useful with Bochs?
My main problems:
1) I read documentations - but i have still problem to set up proper CPU speed, i have problem with slow response time with Filewizzard Filemanager, but in comparsion Doom is running way to faster or slow.
When have to setup some Cmos timer emulation, to make Dos menu timeout working.
2) Not working Sound blaster 16 emulation, i documentation is there is support of it, but i never where able to make it working in DOS. I dunno if i should use Creative SB16 drivers or not.. also sb16ctrl.exe is freezing for me when i use it virtualmachine.
http://bochs.sourceforge.net/doc/docbook/deve … ion-basics.html
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
