First post, by logo_2
Hello Qbix
I have already done the command atp -get install libsdl1.2-dev libsdl-net1.2-devlibpng12-dev
and I get an error Could not find the package libsdl1.2-dev
Ok I did something wrong
could you be so kind to go to the http://www.libsdl.org/download-1.2.php and tell me which package I need to download?
I very appreciate your help
thanks
regards
logo_2
Reply 2 of 4, by logo_2
Qbix
I have never used debian linux before. I used to use Suse. Help me only to compile dosbox is the only thing I need.
thanks
I downloaded the libsdl...deb I renames it to libsdl.deb
I put apt-get install libsdl and I get the same error
why this ?
I'm thinking about to buy a debian-linux book
thanks
logo_2
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
well if you downloaded it you should do dpkg -i filename
You might need several dependencies...
If you want to install software the debian way you should create a working apt.
if you are running testing/stable. You should wait a few days as the dosbox for debian should appear on the debian site soon.
Water flows down the stream
Reply 4 of 4, by logo_2
thanks qbix
I did it and I get a problem because I need x-libs I will downloaded
could be in contact by icq ? my icq is 49270581
If you don´t want is ok .. although thanks a lot
logo_2
