First post, by Whiskers
Open up a terminal
cd to the directory with the games
and run dosbox ./
Heres an example, in this case I am playing Commander Keen
[rob@Oneniisama rob]$
[rob@Oneniisama rob]$ cd /Oneniisama/Keen/
[rob@Oneniisama Keen]$
[rob@Oneniisama Keen]$ dosbox ./
This opens up the dosbox with the current folder as the root directory for dosbox.
No need to switch folders in dosbox now 😀
then in the dosbox window
It will say that it mounted C as the local directory and will have a prompt flashing with C
Doing a dir /w *.exe shows me all the exe files in that folder. I see my Keen1.exe file, and i simple type
Keen1.exe
then the game opens up.
Hopefully someone will made this a sticky message and move this into the tutorial section. This makes it much easier to use dosbox.
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
Whiskers, what happens if you do this:
 [rob@Oneniisama rob]$ dosbox /Oneniisama/Keen/
or this:
 [rob@Oneniisama rob]$ dosbox /Oneniisama/Keen/Keen1.exe
_________________
Reply 2 of 3, by Guest
has the same effect of doing this
Doing this
gets you to the proper directory, then launched the dosbox and the Keen game.
Either way, its a much simplier solution than having to navigate around with dosbox 😀
Reply 3 of 3, by MiniMax
Rank Moderator
Moderator
Great, how about adding your find to the guide? Click here, scroll to the bottom of the page and click Edit this page, and start typing away. Use the Preview button to check the result before pressing Save.
_________________
