First post, by p6889k
I'm currently routing my Awe64 Gold (CT4540) output through the external RCA out connector to Line In on my Audigy, since I use the Audigy as a mixer in both DOS and Windows to then output to Speakers. I used to use Awe64 Value in this setup and that card had a 6 pin internal header (see picture) that could output line or speaker level, which I could then route via internal cable to internal Aux-In header on the Audigy. To my surprise, my Awe64 Gold doesn't have this spk/line header. Is there any way to route Awe64 Gold internally to Aux In on another sound card? I don't see how, but thought I'd ask. SPDIF doesn't seem like a good option since I've read on this board it doesn't output all audio under DOS, only in Windows. How about the MB-PRO 9pin header that exists on both Value and Gold versions?
Thank you.
    199.26 KiB
Sinclair ZX Spectrum 48k, 48k+, 128k, +2
Amiga 1200, 68030/40mhz
386DX/33, ET4000, SBPro2, MT32
Dual PPro/200, Millennium II, Voodoo 2, AWE32, SC-55
etc.
Reply 1 of 2, by p6889k
Just found these two posts about the MB_Pro header. Looks like it has Line Out option, gonna give it a try.
Soundblaster MB_PRO pinout
Sound Blaster Vibra CT2940 (with OPL3) compatible with CT1922?
Also, if anyone is interested, the second link i posted had a link inside to a creative.com page that shows configuration settings for all connectors and jumpers for all creative sound cards. That link is no longer alive, but it still exists on archive.org:
https://web.archive.org/web/20120505013458/ht … e.aspx?sid=3026
etc.
Reply 2 of 2, by p6889k
Problem solved. I used the MB_Pro header pin 5, 7, 9 (Line Left, Line Right, Ground).
etc.
