SpJester wrote on 2020-02-26, 15:05:
При запуске программы DOS выдаёт ошибку(в приложенном файле). Используется Windows 7 x64 и Windows 10 x64 ошибка всегда одинаковая.
When the DOS program starts, it gives an error (in the attached file). Used Windows 7 x64 and Windows 10 x64 error is always the same.
Added a Google Translate translation and split post to separate thread, unlocked.
It's still probably an app not a game tho, looks like the working directory is named REGISTR.
That said, the "FILES=255" problem is referenced many times on this forum.
do the Fandango!" - Queen
Stiletto
