First post, by Synaps3
I got an ASUS CUV4X-E mobo on ebay. The seller said the mobo was tested, but I am having doubts that the seller tested anything except the BIOS.
What happens when I try to boot any OS is the CD will spin up and say the generic message like "system is inspecting hardware..." and then the screen goes blank (but stays on) and just hangs. It does the same with all OSs I tried. Some of them actually display the OS logo at the beginning like TinyXP (which is my preferred OS), but then just hangs and doesn't even let me start the installation. It is clearly reading from the CD drive, but then something goes wrong right after.
It only boots very simple systems. The only thing that boots is memtest and it passes.
I tried replacing all the RAM.
I tried removing all cards except vid card.
I tired replacing IDE cable.
I checked master/slave jumper.
I tried another CD drive.
I tried removing everything except CPU, RAM, vid card, and CD drive (bare essentials).
I tried resetting the BIOS defaults.
Systems:
BOARD | RAM | CPU | GPU
ASUS CUV4X-D | 2GB | 2 x PIII Tualatin ~1.5 GHz | Radeon HD 4650
DELL DIMENSION XPS 466V | 64MB | AMD 5x86 133MHz | Number Nine Ticket to Ride
Sergey Kiselev's Micro8088 10MHz | 640KB | Trident VGA
Reply 1 of 5, by derSammler
Did you actually try something else than XP or at least an original disc and not hacks like TinyXP etc.?
Reply 2 of 5, by Synaps3
I tried Bart PE and Hiren's BootCD. They all do more or less the same thing.
Systems:
Reply 3 of 5, by Synaps3
Alright, I underclocked the CPU and it worked. No, it was not overclocked.
Now I just have to figure out if it's the CPU or the mobo just doesn't want to go full speed for some reason.
I am using a 1.4GHz PIII and maybe this board just isn't going to work with it. I thought it would though cause the CUV4X-D does. It doesn't natively support it without an adapter.
Systems:
Reply 4 of 5, by Synaps3
YES! I figured it out!!!!!!!!!!!!!!!!
Chip Configuration -> CPU-DRAM back to back transaction -> Disabled
Works great so far now. Was able to get the OS to launch. I will actually try installing it at a later time though.
Systems:
Reply 5 of 5, by flupke11
Are your Tualatins on this board and on your CUV4X-D in any way modified to have the 694X accept them?
