First post, by Deksor
Hello ! I have bought a bunch of these cards thinking they were CGA cards at first glance.
But after testing, it's definitely not outputing video.
What could it be ? A MPU401 ?
If so, could it be roland MT32 compatible ?
Reply 1 of 16, by Vynix
I'd say it would be another of those intelligent MPU-401 clones, now to find the pinout of the port...
Reply 2 of 16, by kolderman
If you bought a bunch of them you are very lucky indeed.
Reply 4 of 16, by kolderman
Any bug free, ISA midi card is useful, intelligent mode or not. And you could easily run MUNT on another device and connect this to it using midi2usb adapter. Thankfully awesome people here have made clones of cards like this, but an original would be quite sought after still.
Reply 6 of 16, by keropi
They are indeed intelligent mode compatible midi interfaces, I don't remember atm what games do not work with it (maybe some legend ones? Or wing commander?) but it's way way better than no intelligent mpu at all 😁
Good find!
Reply 7 of 16, by Deksor
cyclone3d wrote on 2020-03-09, 01:26:
Very cool. I have a nice collection of intelligent mode midi cards.
How many of those did you buy.. and at was crazy low price did you get them for?
3-4 of them iirc, and 50€ for the lot they came with (27 mobos, video cards, etc)
Reply 8 of 16, by gdjacobs
keropi wrote on 2020-03-09, 05:24:
Laser Squad and some of the titles from Legend Entertainment (Gateway, Homeworld, Eric the Unready, etc) are the biggest trolls when it comes to normal mode MIDI compatibility. Try those if you want to know what works or doesn't.
Reply 9 of 16, by Stiletto
Moved to Marvin -> General Old Hardware.
do the Fandango!" - Queen
Stiletto
Reply 10 of 16, by yawetaG
That's indeed the MM-401 version. There's another MidiMan ISA card that is merely a serial MIDI interface (i.e. it combines a serial controller and a MIDI interface on a single card so none of your existing serial ports get obstructed).
Reply 11 of 16, by Deksor
So I'm back home, and here's all the cards I have
I swear I had a 4th card, but I can't find it ... maybe my memory is flaky ...
Anyways, the last card is different as you can see, but on the broken sticker on the intel chip I can still read "midi"
Reply 12 of 16, by Deksor
I'm bumping this one year old thread because now I have a midi device so I can test them ... Or I could if I knew the pinout of that DB9 connector ...
I found this on vogons, but I have no idea if it's the right one : Re: Intelligent mode MPU-401 and how it's utilised.
Does anyone around here have one of these card with the cable ? Unless someone comes up with a pinout, I think I'm gonna check it with a multimeter to see if the pinout seems to match and if it does, then I'll make my own cable.
Reply 14 of 16, by megatron-uk
I have one on my desk, with the cable:
The attachment IMG20210328113745.jpg is no longer available
I'll trace it for you now.
https://www.target-earth.net
Reply 15 of 16, by megatron-uk
The attachment MM401-Pinout.jpg is no longer available
9 Pin D-SUB / Connection
1 -> Out 2
2 -> N/C
3 -> N/C
4 -> In 6
5 -> In 2
6 -> Out 4
7 -> NC
8 -> NC
9 -> In 4
The D-Sub shell doesn't appear to have any connectivity.
