First post, by Planet-Dune
I am using that well known 9x dos menu that was posted multiple times on this board in the past. The one where you edit the shortcut to the "launch msdos mode" to run its own config/autoexec and displays a nice choice menu from what type of memory/cdrom you want ..
Now every time I boot into DOS I need to run the "liveinit.bat" to initialize my sound blaster live dos drivers. I figured just to make that go automatically by adding it to the autoexec to notice it refuses to do it... after some research it seems that running a bat from inside a bat is harder than expected and all solutions that I tried don't seem to work...
Anyone know how to do this?
