First post, by AlphaPapa
Greetings vogoneers,
I have been playing around with attaching my system to an early HDTV Plasma
great colors and black levels. Its Native panel resolution is actually 848 x 480
thus my request for suggestions.
Games that look good at 640x480 or can be modified or enumerate resolutions from dx and can do widescreen.
I have played some more current games and even when I sit at the correct viewing distance; that I cannot differentiate individual pixels, still the UI/Hud and text sizes just make the games look garbagey.
Even on ultra settings Anti-Aliasing etc, so Gotta go back in time when games were designed for low res displays.
What classic games in your opinion should I play that look good and are designed for low res AND are easily setup to use a gamepad/joystick.
Following that games that are less easy to use a gamepad, though remapping software and or DOSBOX mapper. However are still excellent in gameplay today and look good at low rez. I think I will be starting with The keen series and Prince of Persia using dosbox mapper.
