40 pin cdb-231
First post, by xtgold
I found the sony 8 bit card in the archives but is useless without the original proprietary 1x sony drive.
I also found the floppy with the drivers.
It is a 40 pin connector,not 34 pin like previous sony.
All the odd pins on the connector are tied to ground.
Reply 1 of 3, by Horun
xtgold wrote on 2020-03-13, 13:43:
I found the sony 8 bit card in the archives but is useless without the original proprietary 1x sony drive. I also found the flo […]
Some early Sony were 40pin, they were called SLCD Interface. The Sony 2x CDROMS (like CDU33A) were 34pin. Always hated the proprietary cdrom interfaces...
Reply 2 of 3, by xtgold
opti 82c930a based sound card IPC mpn: PCBISP32&2 has a 40 pin connector labeled ide,but I don't know if it's real ide or one of the proprietary models.
Reply 3 of 3, by derSammler
It's real IDE if it says that. There is no "fake" IDE.
