First post, by th1r5bvn23
I've got an AWE64D CT4655 card on my hand recently. However, I could only find driver for Windows 9x and Windows 2000. It would be greatly appreciated if someone can provide DOS driver for this card.
AMD K6-2+ 500, FIC PA-2013 2.0 (1MB cache), 128MB SDRAM PC100, Voodoo3 3000 AGP, Labway Yamaha YMF719B-S with NEC XR385
AMD Athlon 64 3000+, ECS K8M800-M3, 512MB DDR 400, GeForce FX 5200, SoundBlaster Live! SB0060
Reply 1 of 3, by th1r5bvn23
Photos of the card:
1.88 MiB
Front side
1.4 MiB
Back side
Reply 2 of 3, by cyclone3d
They are still available straight from Creative Labs. Looks like it uses the same drivers/config/utilities as the ISA cards.
Listed under:
other -> archived products -> SB AWE64 Digital
And it is a CT4650, not a CT4655.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 3, by th1r5bvn23
cyclone3d wrote on 2020-03-16, 03:13:
I indeed went to Creative website and found exactly the same drivers as AWE64 ISA. However, I also found conflict statement on Wikipedia:
Wikipedia wrote:
AWE64 PCI was later followed by the AWE64D, which was a variant of the PCI AWE64 that was developed for OEMs. It again offered the same feature support as other AWE64 cards, including the DOS support issues. The AWE64D was not quite compatible with AWE64 PCI drivers, however, and had to use separate driver packages.
There isn't any citation on that page. I don't think there's another "AWE64 PCI". Maybe if I use SB-Link, I can just use DOS driver for AWE64 ISA? But I'm sure in Windows it uses another driver package because I've found it: Windows 9x&NT / Windows 2000
I've also read somewhere (Chinese forum) that AWE64D driver for Windows XP is unstable and often causes the system to BSOD.
The sticker on the back side of the card says CT4655. I did manage to find the difference between CT4650. There's no SPDIF_CONN pin soldered on CT4650, and SUBSYS ID is 00301102 for CT4650 and 00311102 for CT4655. I think I also found the difference between CT4600 and CT4601. CT4601 eliminated onboard amplifier, though they share the same SUBSYS ID.
