First post, by Perplex
I think I’m just hoping for the best and not facing reality. I had the card in a p3 system whose psu (and replacement) started spitting out smoke. I thought just old caps.
Anyway I just got a new p2 on a 440lx motherboard and I now get artifacts. The card does it’s voodoo3 initial pre post-post (if that’s makes sense) without artifacts and other select text on black screen works fine.
I guess some ram has been fried on the gpubut I’m half hoping it’s actually an issue with the motherboard.
Without further ado - I welcome any visual diagnostics. Is this voodoo3 toast or is there hope?
Cheers
The attachment 1211CE75-960A-4FEE-8993-8F463D29C7FE.jpeg is no longer available
I have an awe64 gold that was in the same system I’m scared to test - will be sad if that’s been fried too 🙁:(
Reply 1 of 9, by Perplex
I guess from the numerous comments I’ll assume dead - it’s going in the bin 😀
Reply 2 of 9, by fitzpatr
Perplex wrote on 2020-03-20, 14:10:
Not dead, but defective. A memory chip has probably failed. If it has and you can identify/replace, it should work again. With current prices, it's worth it, IMO.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 3 of 9, by aaronkatrini
Never throw a 3dfx card in the bin or I call the police!
Reply 4 of 9, by Perplex
fitzpatr wrote on 2020-03-20, 14:13:
I will do my own research on how to test and identify which chip. However - Any advice to help short cut the process is welcome
Reply 5 of 9, by Perplex
aaronkatrini wrote on 2020-03-20, 18:00:
Haha no I wouldn’t don’t worry - If I cant fix it ill give it away or keep hold of it for someone the fix in the future
Reply 6 of 9, by matze79
You still can use it with a BB Gun.
Reply 7 of 9, by Thermalwrong
I think if your card got flexed when moving it from one PC to another or when changing a heatsink, that could be causing what you're seeing.
I've got something similar, I had a working Voodoo 3 3000 that become not-working when I fitted a bigger heatsink to it. I heard a small *tink* sound when screwing down the heatsink and the card now just shows artifacts on startup. It's probably fixable if we can work out a safe temperature to cook the card at to reflow the leaded solder on the BGA chip. Other people have had a go at it previously and I recall them saying it just melted into a puddle of solder, so the melt point must be quite low.
Reply 8 of 9, by Perplex
So we need a heat gun? Or some sort of accurate and variable temperature oven of sorts 🤣 😉
Reply 9 of 9, by Perplex
Or leave it out in the sun
