First post, by MMaximus
- Oldbie
I recently bought a used Panasonic JU-455-7AAG 360Kb floppy drive - It was listed as untested but after lubricating the rails and cleaning the heads it seems to be in good mechanical condition.
The drive initializes at boot, the LED lights up and it can boot to a DOS floppy. However when trying to access the drive, the LED lights up but the spindle won't start. A DIR command makes the system hang before giving the "drive not ready error". If I type "DIR" and quickly insert the floppy then put the lever down, the disk reads because inserting a new disk makes the spindle move temporarily.
I tested with another 360k drive (Matsushita JA-551-017) and It displays the exact same behaviour. OTOH A 1.2M drive (TEAC FD-55GFR) works fine in the same machine.
I'm using a MIO-AT controller card in a 386 PC.
I've read that some controller cards can't output enough power to drive the spindle of a 360Kb drive. Does anyone know anything about this?
