First post, by fool
Got one i815 mobo with some kind of turboPLL mod. There is this second board cut away from another mobo and it's not very nice looking work. For example there are long wires and resistors close to mobo traces for and crystal is just put to a connector with leads... I belive this is supposed to keep PCI/AGP clocks locked while FSB is increased? Someone with more knowledge about these mods can tell me more.
Yeah, it kind of works. Floppy controller is giving me I/O error when reading. Hard drive is acting like there are bad sectors when formatting but none is marked. Got Win98SE installed fine after some HDD format attempts. I think this mod is not working perfectly. I will check what PCI&etc clocks are. Running with 1000MHz coppermine with 133FSB. Could be one thing to test dropping FSB to 100, just don't know how to do it with this mobo.
I would remove it but some caps and resistors are missing.
file.php?mode=view&id=79926
file.php?mode=view&id=79925
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 1 of 4, by fool
I just decided to remove the mod because of the floppy fail and AC97 is not recognized. Only one resistor array pad is missing and can be wired.
If there is someone with this same MSI 815E mobo could you please take a photo from the PLL chip area like in the attachement? I would really appreciate it. Looks like most of the caps are 10pF and resistors some low 10-33 ohm value, but from a photo I could find the right values for resistors and NC components.
Reply 2 of 4, by AvalonH
On my motherboard is printed '815E PRO VER:1' MS-6337, I don't know what revision you have.
The attachment IMG_20200405_151322336_HDR.jpg is no longer available
The attachment IMG_20200405_145653813.jpg is no longer available
The attachment IMG_20200405_151509255.jpg is no longer available
The attachment IMG_20200405_151538708.jpg is no longer available
Reply 3 of 4, by fool
Thank you wery much! That is just the photo I've been looking for. My board version is the same (v. 1).
It's running stable now, with working floppy disk. Hard disk bad sector failures was a result of poor power supply (leaked caps).
Reply 4 of 4, by pentiumspeed
No, first picture is one you need to fill in missing components.
The last picture is does not match what your motherboard has.
Great Northern aka Canada.
