First post, by GabrielKnight123
I have the GOG bought version of GK2 and it is patched so that the scan lines are removed, is there a way to re enable them? Im using GOG's version so I can copy the whole game to the hard drive and play it in dos. There is a gk2.ini file with "enable_black_lined_video=false" making this to "true" does not work and this file is called from Scummvm by the looks of it because the shortcut the GOG installer makes on the desktop has ""C:\Games\Gabriel Knight 2\scummvm\scummvm.exe" -c "..\gk2.ini" gk2".
