First post, by boxpressed
Has anyone gotten their Diamond Monster Sound MX200 to function properly with 98SE? This is the Diamond card with the Analog Devices DSP (not the MX300 with Aureal Vortex 2).
98SE recognizes the card upon startup and loads the driver from the 98SE CD. It works fine at this point with Windows sounds and games.
However, Windows does not load the MPU-401 driver or Sound Blaster compatible-legacy drivers. I want to use the wavetable header with its 4MB daughtercard to play DOS games launched from 98SE.
So I downloaded the ms10706w.exe file from vogonsdrivers and installed the drivers. After that point, I do get the MPU-401 and SB legacy devices showing up in Device Manager, and there don't appear to be any resource conflicts, but now there is no sound for Windows events or games anymore.
When I reboot, it appears that a DOS program in some batch file is loading a file into the DSP. When Windows begins, I get a popup that says that the "Monster Sound DSP file is obsolete ..." No sounds in Windows or DOS.
I've tried two different MX200 cards in two different 98SE builds with the same results. What am I doing wrong?
Reply 1 of 2, by boxpressed
As Murphy's Law would have it, shortly after I post a question, I solved the problem. I'll post the solution here in case anyone runs into the same problem. The install process reports that a couple of files you have in your system already are newer than the ones being installed. It asks if you want to keep them. I answered "yes" (keep the file) but should have answered "no." Apparently, mixing the files creates a conflict between the built-in 98SE Monster Sound driver and the Diamond MPU-401 and SB Legacy drivers.
Reply 2 of 2, by thatoneguy
Sorry to revive an old thread (and as my first post to boot) but I'm having the exact same issue as OP... Tried multiple installs of 98 (about to try a fresh install of 95) and everything else seems to work on the card except I can't get any MIDI playback. With all the drivers updated I can even see the DreamFX tab in the Diamond app but I can't playback any .midi files. OP mentions a couple of files that get overwritten (I think they are vjoyd.vxd and msjstick.drv) but nothing I do gets MIDI playback working. I'm just trying to make sure this card works before I sell it.
I'm pretty sure it's an MX200 (although the board just says Monster Sound Gold), so I'm including a pics for reference. Thanks in advance for any pointers on what I'm doing wrong.
